coos nog eens onder de loep
08-05-2007 20:24 #1165418 door V700 register
Beantwoord door V700 register in topic Euh.....
triton schreef : Is het mogelijk dat hier een massa probleem zit?
Ja?
Dat ding zit toch koud tegen het blok? Ik neem toch aan dat die massa ndig heeft, en lijn geleid niet........
Ik ga eens zoeken.........
08-05-2007 21:15 #1165427 door V700 register
Beantwoord door V700 register in topic Geen plug and play.
Eerder plug and pray:
Zie tekst afkomstig van Swedishbricks:
Swedishbricks schreef : <font face="Arial,Helvetica">Replacing RPM or Hall Sensors.</font> <font face="Arial,Helvetica">RPM Sensor:  If your car is a non-turbo 89+ model then it has a flywheel reading RPM/Position sensor that is down below the rear of the cylinder head, mounted on the bellhousing through a bracket retained by one bolt that should be a 10mm head on a 89. It is connected to wires above the engine on the firewall.</font> <font face="Arial,Helvetica">Hall Sensor:  If it is 89 turbo or pre-89 then it has the Hall switch that is in distributor. The Hall switch is tough as it requires that you knock out a pin and pull out the shaft, then VERY carefully drill out a couple of pins that retain the hall switch. Then you have to be very careful about supporting the distributor base while bradding the retainer pins to retain the new hall switch. If you slip while bradding the pins then you punch out a hole in the base and then you need a new distributor.  [Response 2:] Changing that is not for the novice. It is riveted into the distributor. Some dealers offer rebuilt exchange on the distributors. Before you jump to the hall sensor, carefully examine the wires from the firewall to the distributor, which sometimes break inside from years of flexing. These can be repaired with a little work. Also, check the brittle plastic connector where the wires go into the distributor. This can cause intermittent shorting. The plastic fitting is Volvo PN 1346793, about $3.00 as I recall. If you are going to remove the distributor for any reason, carefully scribe a mark to return it to its exact former position so as not to change the timing (the holes in the distributor are slotted). [Response 3:] I&#39;ve done few of these. Never alone, however.  Drill out the old rivets carefully and pry out the sensor.  Next, have an assistant you can trust with approximately $ 70.00 hold the new sensor in its proper place on the distributor plate.  Place a steel punch of roughly same diameter as the rivets into the bench wise. Have the assistant hold the D. plate in such a way that the rivet is directly over the punch.  Now, YOU, using the second punch and a hammer CAREFULLY hit the top part of the rivet. It will take MANY hits since these darn rivets are made of steel. The key here is steady hands, and frequent breaks. One wrong move, and you are done. Simple physics tell you which, steel or aluminum will crack first under constant hammering.</font> <font face="Arial,Helvetica">This is akin to putting a horse shoe onto an a hard boiled egg, possible but  very nerve wracking.</font>
Dus................
09-05-2007 18:04 #1165499 door V700 register
Beantwoord door V700 register in topic Plaatje gevonden.
En kijkend naar het plaatje ben ik wel benieuwd wat je precies gelijmt hebt.
<img src=" www.volvoclub.org.uk/faq/ImagesProcedure...ibutorHallSensor.gif " border="0" alt=" " width="320" height="348" />
Als ik zo zie hoe de constructie van het ding (ik heb hem nog nooit live gezien, dus wellicht zijn er verschillende) kan je het er niet zomaar uithalen en weer lijmen.
Kan dat wel, dan lijkt ie me echt heel erg stuk, en doet het blok dus inderdaad niets.
09-05-2007 20:57 #1165511 door V700 register
Beantwoord door V700 register in topic hall sensor
Je kan het zwarte gedeelte in de verdeler eruit boren en een nieuwe halen die je dus moet klinken door de 2 metalen pennen.
Maar ik stond alleen en om dan de metalen pennen te klinken in een aluminium huis is lastig.Maar mijn vraag is dus of deze door middel van klinken dus massa moet maken op het huis of krijgt deze zijn massa doormiddel van de zwarte draad inde stekker?
Andre
  • Timen Smit
09-05-2007 22:42 #1165531 door Timen Smit
Beantwoord door Timen Smit in topic Klinknagels
De klinknagels hebben alleen maar de functie van vastzetten. Het heeft niets met de massa te maken. Knap dat je dat gelijmd hebt, dat lukt mij haast nooit en als het dan vastzit gaat het later wel weer los.
Heb je misschien de meenemer soms niet goed gemonteerd. De rotor staat dan niet tegenover de contactpunten.
Timen
09-05-2007 22:50 #1165536 door V700 register
Beantwoord door V700 register in topic meenemer
De meenemer zit er goed op en alles staat perfect op tijd maar nog steeds geen plof in de uitlaat of iets wat maar enigzins op ontbranding lijkt.
&#160;
Andre
09-05-2007 22:56 #1165538 door Jeroen van Bodegom
Beantwoord door Jeroen van Bodegom in topic Ploft ie ook niet als je
Ploft ie ook niet als je brandbaar gas inspuit via het luchtfilterhuis?
Een spuitbus Cold start of remmenreiniger of iets dergelijks moet werken.
13-05-2007 19:37 #1165882 door V700 register
Beantwoord door V700 register in topic Klinken
Ik heb het 1 keer gedaan en het was goed te doen, 1 drevel rechtop in de bankschroef eronder en met een andere op de klinknagel meppen. Ik kan me wel herrinneren dat je ergens een asje uit moest tikken dat er op 2 manieren weer op kon. Staat het verdeelhuis wel weer in de oude stand? anders een beetje verdraaien proberen.
Succes!
07-06-2007 10:10 #1168778 door V700 register
Beantwoord door V700 register in topic Hall-sensor.
Stel dat de Hall-sensor niet werkt of ontbreekt of geen signaal geeft, zou de motor dan wel moeten werken en dus moeten aanslaan?
Met andere woorden: Wat is er minimaal nodig om de motor te laten aanslaan.In mijn optiek: Brandstof en brandstofdruk, vonk en ontsteking (op het juiste tijdstip), prik en lucht.
Lambda is niet boeiend volgens mij, zonder knock-sensor loopt ie ook maar beroerd, temp-sensor is niet boeiend bij starten, LMM heb je ook niet nodig. Hall-gever twijfel ik nog over, vandaar mijn vraag.
Ben ik iets vergeten?
  • Mathy van Nisselroy
  • Junior lid
  • Junior lid
07-06-2007 11:14 #1168788 door Mathy van Nisselroy
Beantwoord door Mathy van Nisselroy in topic Dan doet ie het niet
Hallo Bas
De Hall-gever vertelt de motor wanneer er een vonk moet komen. Is zeg maar de vervangen van de contactpunten. Zonder doet ie het dus niet.
Groetjes
