startproblemen brandstofpomp
<img src="/sites/default/public_files/images/injectorrelais.preview.jpg" width="480" height="640" />henk 940LPT schreef : Kun je eens een foto van dat ding maken Bas ?
Had deze trouwens al eens eerder gepost in een <a href="/node/33210#comment-169061" target="_blank">draadje van Bas</a>
- Jerry Stam (GAST)
Dit leek me nog wel nuttige info rondom het relais:
It is a Volvo Radio suppression relay.Used on models '86 and newer LH injection systems. It's called radio suppression relay but it's real function is to supply positive (+) power to fuel injectors. It is identical to the cooling fan relay.
Problem diagnosis:1.- car failure to start until it cools down. 2.- back firing and poor acceleration. 3.- no pulse to injectors.
Hier zit ie ook in: ... VOLVO 240 year Type liter del. asp. vin designation where used position notes 1993 L4 2.3 FI N 8 B230F Starter Relay 1992 L4 2.3 FI N 8 B230F Starter Relay 1991 L4 2.3 FI N 8 B230F Starter Relay 1990 L4 2.3 FI N 8 B230F Starter Relay VOLVO 245 year Type liter del. asp. vin designation where used position notes 1985 L4 2.3 FI N 8 B230F Starter Relay 1984 L6 2.4 FI N 7 D24 Starter Relay Diesel VOLVO 740 year Type liter del. asp. vin designation where used position notes 1992 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo 1991 L4 2.3 FI N 8 B230F Radiator Fan Relay 8v; A/C Cooling Fan Relay 1990 L4 2.3 FI N 8 B230F Radiator Fan Relay 8v; A/C Cooling Fan Relay 1990 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo VOLVO 760 year Type liter del. asp. vin designation where used position notes 1990 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo 1989 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo VOLVO 780 year Type liter del. asp. vin designation where used position notes 1991 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo 1990 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo 1990 V6 2.8 FI N 6 B280F Radiator Fan Relay VOLVO 940 year Type liter del. asp. vin designation where used position notes 1995 L4 2.3 FI T 8 B230FT Radiator Fan Relay 8v; A/C Cooling Fan Relay VOLVO 240 DL year Type liter del. asp. vin designation where used position notes 1990 L4 2.3 FI N 8 B230F Starter Relay VOLVO 244 DL year Type liter del. asp. vin designation where used position notes 1989 L4 2.3 FI N 8 B230F Starter Relay 1988 L4 2.3 FI N 8 B230F Starter Relay 1987 L4 2.3 FI N 8 B230F Starter Relay 1986 L4 2.3 FI N 8 B230F Starter Relay 1985 L4 2.3 FI N 8 B230F Starter Relay 1984 L6 2.4 FI N 7 D24 Starter Relay Diesel 1982 L6 2.4 FI N 7 D24 Starter Relay Diesel VOLVO 245 DL year Type liter del. asp. vin designation where used position notes 1989 L4 2.3 FI N 8 B230F Starter Relay 1988 L4 2.3 FI N 8 B230F Starter Relay 1987 L4 2.3 FI N 8 B230F Starter Relay 1986 L4 2.3 FI N 8 B230F Starter Relay 1982 L6 2.4 FI N 7 D24 Starter Relay Diesel VOLVO 240 GL year Type liter del. asp. vin designation where used position notes 1992 L4 2.3 FI N 8 B230F Starter Relay VOLVO 244 GL year Type liter del. asp. vin designation where used position notes 1989 L4 2.3 FI N 8 B230F Starter Relay 1988 L4 2.3 FI N 8 B230F Starter Relay 1987 L4 2.3 FI N 8 B230F Starter Relay 1986 L4 2.3 FI N 8 B230F Starter Relay 1985 L4 2.3 FI N 8 B230F Starter Relay 1984 L6 2.4 FI N 7 D24 Starter Relay Diesel 1983 L6 2.4 FI N 7 D24 Starter Relay Diesel 1982 L6 2.4 FI N 7 D24 Starter Relay Diesel VOLVO 245 GL year Type liter del. asp. vin designation where used position notes 1989 L4 2.3 FI N 8 B230F Starter Relay 1988 L4 2.3 FI N 8 B230F Starter Relay 1987 L4 2.3 FI N 8 B230F Starter Relay 1986 L4 2.3 FI N 8 B230F Starter Relay 1983 L6 2.4 FI N 7 D24 Starter Relay Diesel VOLVO 740 GL year Type liter del. asp. vin designation where used position notes 1990 L4 2.3 FI N 8 B230F Radiator Fan Relay 8v; A/C Cooling Fan Relay VOLVO 740 GLE year Type liter del. asp. vin designation where used position notes 1990 L4 2.3 FI N 8 B234F Radiator Fan Relay 8v; A/C Cooling Fan Relay VOLVO 760 GLE year Type liter del. asp. vin designation where used position notes 1990 V6 2.8 FI N 6 B280F Radiator Fan Relay 1988 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo VOLVO 940 GLE year Type liter del. asp. vin designation where used position notes 1991 L4 2.3 FI N 8 B234F Radiator Fan Relay A/C Cooling Fan Relay VOLVO 240 SE year Type liter del. asp. vin designation where used position notes 1991 L4 2.3 FI N 8 B230F Starter Relay VOLVO 740 SE year Type liter del. asp. vin designation where used position notes 1991 L4 2.3 FI T 8 B230FT Radiator Fan Relay Turbo
Kan ik er wat aan doormeten? Weet iemand hoe? Of is het een kwestie van uitruilen met een goede?
Stephan
97 230FK
Ik heb die van mij open geprutst en kon er helemaal NIETS aan zien.Met een louppe gekeken, geen beschadigingensavdijk schreef : Vanavond heb ik het Radio suppression relay gelocaliseerd. En even er af gehaald.
Vervangen voor een bewezen werkend of nieuw exemplaar, lijkt me dan het beste.Erg duur kan ie niet zijn, toch?
Is dat niet inherent aan het fenomeen "identiek"?Baseman schreef : Ha, gelukkig, ik ben dus niet de enige met een IDENTIEK probleem.
Het begon eigenlijk al eerder. Bij een lege tank, lampje brandt nog niet maar wijzer staat laag, moet je behoorlijk langer starten dan bij een volle tank. Eerste gedachte: pomp zit niet goed in de tank. Ook sloeg de motor twee keer af bij afremmen bij een legere tank.
Maar voordat ik dat kon checken heb ik nu het startprobleem.
Mijn zaterdagmorgen verliep als volgt:
Thuisweggereden, prima start,
boodschappen gedaan, ingeladen, prima start,
achteruit het parkeervak uit, afslaan, nooit meer starten........tot,
gisterenmiddag mijn zoon haalde hem zo op voor de super....
Thuis voor de garage, twee keer goed starten daarna niet meer.
Gechecked:
Ander benzinepomp relais. Geen succes.
Benzine toevoer: Spuit vanaf de benzineleiding over de radiator, als je het contact omdraait. Lijkt me genoeg.
Het zwarte inspuitrelais aangesloten op een losse 12V. Schakelt prima, maar....
blijft ingeschakeld als het contact wordt uitgezet.
Is dit normaal?
Heeft iemand suggesties waar ik moet zoeken? Hoe check ik de computer?
Bedankt maar weer.
Stephan. 230FK (staat stil )
- Timen Smit
Kun je niet beter de benzinedruk meten? Je weet dan meteen of de drukregelaar goed is. Op de brandstofrail zit hiervoor bij de typen na ± 1991 een speciaal ventiel.savdijk schreef : Na een paar weken goed starten, met een volle tank, heeft zich gisteren weer een startprobleem aangediend.
Gechecked:
Is dit normaal?
Bedankt maar weer.
De computer uitsluiten, kun je door er even een andere aan te hangen. Moet je wel het (Bosch)nummer eerst opzoeken.
<img src="/sites/default/public_files/user923/Meten_van_de_benzinedruk_in_de_rail_0.jpg" width="492" height="369" />
Net heb ik de vliegwielsensor er uitgehaald en schoongemaakt. De eindtrap verwisseld.
De motor sloeg meteen aan. Nu moet je natuurlijk niet twee dingen tegelijk vervangen als je wilt weten wat het is, maar we waren met z'n tweeën. De eindtrap weer teruggewisseld en nu doet hij het nog steeds.
Nu maar afwachten of dat het was.
Bedankt voor het meedenken allemaal.
Stephan.
Lid: 569
