Paravent demonteren
  • Eric Bakker (GAST)
12-01-2007 19:02 #1058028 door Eric Bakker (GAST)
Paravent demonteren is gemaakt door Eric Bakker (GAST)
Hierbij o.a. op verzoek van Mathy de foto s.
Heb zeker 6 Volvo s gesloopt voor ik er eentje had waarbij de plastic kap goed zat.
De sloop-740TIC
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168623756 " border="0" alt="image" width="448" height="336" />
Men haalt de ruiterwissers eraf
En dan dit boutje.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168623857 " border="0" alt="image" width="448" height="277" />
Dan rechts en links deze boutjes.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168623916 " border="0" alt="image" width="448" height="278" />
Nu de kap er voorzichtig af halen.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168623984 " border="0" alt="image" width="448" height="336" />
Daar is de plastic kap.
(DEZE ZIT NIET GOED )
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168624042 " border="0" alt="image" width="448" height="336" />
De plastic kap.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168624095 " border="0" alt="image" width="448" height="287" />
Zo ziet het eruit zonder plastic kap.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168624159 " border="0" alt="image" width="448" height="336" />
Onder dat gat zit de kachelmotor.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168624200 " border="0" alt="image" width="336" height="448" />
Zo hoort de plastic kap te zitten.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168624256 " border="0" alt="image" width="336" height="448" />
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168624282 " border="0" alt="image" width="448" height="336" />
12-01-2007 20:08 #1153808 door V700 register
Beantwoord door V700 register in topic Paravent foto´s
Hallo Mathy en Frits,
Geweldige foto´s, duidelijk heel handig om mijn lekkage aan de bijrijder´s kant proberen op telossen. Daar lekt het langzaam weg onder de vloermat. Ik denk het weg komt bij de verwarming of zo. Het schuine stuk waar de voeten liggen daar komt het zo tezien weg. Dat wordt me nog een speurtocht.
Groeten Roelof.
  • Mathy van Nisselroy
  • Junior lid
  • Junior lid
13-01-2007 00:31 #1153852 door Mathy van Nisselroy
Beantwoord door Mathy van Nisselroy in topic Rooster
Hallo Frits
Hoe wordt de lucht vanaf het rooster in de paravan naar die kap geleidt?
  • André Struis
13-01-2007 00:39 #1153853 door André Struis
Beantwoord door André Struis in topic Wind
Tocht is wind in huis (Reve)
Achterin de auto zitten ontluchtings gaten.Hierdoor ontstaat tijdens het rijden een onderdruk in de auto die aangevuld wordt door de rijwind via de paravan.
13-01-2007 01:57 #1153862 door V700 register
Beantwoord door V700 register in topic Snap niet
Mathy schreef : Hallo Frits
Mathy,
Snap je vraag niet.
Heb je wat aan deze foto?
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168649190 " alt="image" width="448" height="336" />
  • Junior lid
  • Junior lid
13-01-2007 01:58 #1153866 door Mathy van Nisselroy
Beantwoord door Mathy van Nisselroy in topic Zo beter?
Hallo Frits
De lucht wordt door die kap die je gefotografeerd hebt in het ventilatie systeem geleid. In de paravan/paravent zit een rooster. Is dat rooster op de een of andere manier met die kap verbonden? Zit er onder dat rooster nog iets, dat de lucht naar die kap leidt? Dat zie ik namelijk niet op die foto&#39;s.
Even voor de duidelijkheid, die kap zit OVER het gat en de lucht loopt onder de kap door het gat in, of zie ik dat verkeerd? En loopt de lucht OVER de kap?
Edit: ja, aan die foto heb ik wat.  Maar ik vraag me nog steeds af of die kap OVER het gat (waar de ventilator onder zit) zit of niet.  Ik vermoed van wel.
13-01-2007 10:39 #1153875 door V700 register
Beantwoord door V700 register in topic Geen verbinding.
Tenzij het bij mij ook niet goed zat, verbaasde ik me ook al over dezelfde vraag, Mathy.
Er zit bij mij ook geen verbindings/geleidingskap die de luchtstroom vanaf het rooster naar de blowerinlaat.
Overigens is het meer dan logisch dat dat niet het geval is, want onder de paravent zitten nog meer gaten die lucht door je chassis blazen. Er wordt als het goed is lucht door de chassisbalken maar ook door de dorpels geleid om opeenhoping van vocht en water te voorkomen en daardoor ook roest tegen te gaan.
Maak je die dicht....tsja.........
13-01-2007 11:58 #1153882 door V700 register
Beantwoord door V700 register in topic Rooster
Mathy,
Dat rooster is niet met de plastic kap verbonden.
Als je dit rooster bedoelt.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168684144 " alt="image" width="317" height="153" />
De plastic kap is er naar mijn idee alleen maar om ervoor te zorgen dat er geen water in de kachelmotor komt en voor de luchtstroom naar de ventilator.
Het is belangrijk dat de kap tegen de voorruit kant goed waterdicht is afgekit.
Als de kap wat gaat hangen(zie foto hieronder) dan ga je aan de kitrand trekken waardoor er een kiertje cq scheurtje in de kit kan komen. Met als gevolg lekkage.
<img src=" i129.photobucket.com/albums/p228/740esta...web.jpg?t=1168685279 " alt="image" width="448" height="336" />
De kap zit boven het gat van de venilator.
Ja de lucht loopt onder de kap door het gat in . Anders zou de kachelmotor (ventilator) geen lucht kunnen aanzuigen.
In de kap zitten soort waterafvoer gootjes.
Hoop dat een en ander beetje duidelijk is.
We kunnen er ook altijd nog even over praten op sleuteldag
27 Jan.
 Enne Bas ik heb op de sloop ook nog even bij een 940 gekeken.
Die plastic kap is veel kleiner dan bij de 740.
Waarom ?? geen idee
13-01-2007 17:23 #1153920 door V700 register
Beantwoord door V700 register in topic Stouten!!!!
Ik herken de plaats en de auto! Je bent bij de firma Stouten geweest. Beetje goed geholpen??
Groetjes Eddy.
13-01-2007 17:43 #1153926 door V700 register
Eddy,
Klopt ben bij Stouten geweest.
Ben goed geholpen. Ben er al vaker geweest.
Ik vind het prima mensen.
