R/M
17-10-2009 12:05 #629660
R/M is gemaakt door V300 register
Hello, everybody.
I have a question about the cvt...
I have put a rev.counter in my car and at "normal" driving it goes between 2800-4200r/m at speeds between 70-110km/h. The r/m never goes under 2800?when I climb of the gaspedal... Is that right? When the speed goes down the rotation follows, but I thought that the rotations could get down a little bit more when I drive at the same speed (for example 90km/h). No wonder that it consume about 1l/10km...
Maybe I have to add that the engine is brand new and has only gone 5000km. Does an engine consume more petrol in the beginning??
17-10-2009 12:12 #802341
door Anjo van den Akker
Beantwoord door Anjo van den Akker in topic R/M
Hi Christer and welcome to this forum!
that mileage is pretty rare, especcialy on a 343!! but it won't be the reason for the 1:10 fuel consumption.
i've copied the table from the main website for you:
50km/h 1800 r.p.m.
60km/h 2100 r.p.m.
70km/h 2500 r.p.m.
80km/h 2900 r.p.m.
100km/h 3600 r.p.m.
120km/h 4400 r.p.m.
130km/h 4700 r.p.m.
if the rpm's match up the cvt will be fine, if not you'll have to check the clutch adjustment, condition of the vacuum system, and check the condition of the driving belts and the adjustment gap on the secundary pulley's
if those are all ok; give the carb a full cleanup and refurbishment (and the engine a service if you haven't done that yet) with that kind of mileage over the years dirt can easaly mess up some adjustments.
50km/h 1800 r.p.m.
60km/h 2100 r.p.m.
70km/h 2500 r.p.m.
80km/h 2900 r.p.m.
100km/h 3600 r.p.m.
120km/h 4400 r.p.m.
130km/h 4700 r.p.m.
17-10-2009 12:48 #802343
Beantwoord door V300 register in topic R/M
I went out to check and got this.
In normal driving at 90km/h it goes about 3800-4000 depending on the road.
This data I got when I deaccellerated.
130km/h 4700 (4800)r.p.m.
120km/h 4400 (4400)r.p.m.
100km/h 3600 (3800)r.p.m.
80km/h 2900 (3300)r.p.m.
70km/h 2500 (3000)r.p.m.
60km/h 2100 (2200)r.p.m.
50km/h 1800 (2000)r.p.m.
I have changed the belts but not yet adjusted them the second time. Maybe I should do that and check the vacuumsystem...
17-10-2009 13:02 #802344
Could we see some bigger pictures? This car is awesome!
17-10-2009 16:13 #802352
Take a look at:
www.garaget.org/nedcarsamlaren
17-10-2009 16:17 #802353
As good as new, nice car! It will be good to adjust the belts for the second time after replacing/changing!
17-10-2009 16:33 #802356
Thankyou!!!
One thing I miss at the car is a stripekit at the side. Volvo had one that fits between the wheelhouses with three lines that had different grey colour.
17-10-2009 16:34 #802358
I prefer the car without any stripekit. Some new 360's or other coloured 343's/345's but not this one. It looks very clean and original without stripekit!
17-10-2009 16:41 #802359
Wow, this really is a damn fine 343. You almost convinced me to place a louvred panel.
I see you placed a newer type of B14 (besides that it's practically new), is that correct?
Show (off) your car at the Dutch Volvo Fair next week or year!![;) ;)]()
edit: the "anniversary" striping at the back would fit this car perfectly, I think.
17-10-2009 17:21 #802361
Thanks again!
I can agree with you(slb340) but the point with this car is to find as much bling bling(Volvo original of course) as I can. I have installed el.mirrors, spoiler, jalusi, 4 loudspeakers, rev.counter and X-lights so far and more to come I hope. It?s not easy to find such old parts...
