M90 versnellinsgsbak in 760 Turbo uit 1986
  • Boris Duijndam (GAST)
29-03-2009 20:54 #1073463 door Boris Duijndam (GAST)
M90 versnellinsgsbak in 760 Turbo uit 1986 is gemaakt door Boris Duijndam (GAST)
Gekopierd van het draadje dat ik op turbobricks had gemaakt maar vond het wel leuk genoeg om ook met jullie te delen , maar vandaar dat het engels is ;-)
Yesterday i drove to J2's garage.. here are a few pics
White-Rice on the bridge
I might have gone offroad a few days ago...
Removing the M46
M90 diesel plates mounted on the motronic flywheel
M90 installed on the B230ET
Time to fool around a bit!
Some more volvo humping
What WR looks likes on the bridge while being passed out on the ground
Back to business, Putting back the shorter drive shaft
The old dirty and used broken M46 she will be missed.. erghmmm
Difference between the M46 gearbox mount and the M90 one, so be sure to get it
Difference between the M46 gearbox drive shaft and the M90 one, so be sure to get it (shorter one is the M46 FYI)
There are too different partnr's for M90 oil
So there you have it we put swapped the M90 in the car within a day at ease .. the ride is SOOOOO much better now! Sure the M46 was broken but still the difference is so noticeable and a real 5th gear is also very nice.
Mind you that the move to the 5th gear and also the 3th gear are different so take it easy when you just did the swap .. for the first time in my life i even was careful!
29-03-2009 20:57 #1233547 door V700 register
Beantwoord door V700 register in topic leuk
jammer dat de foto's niet zichtbaar zijn.
hier de eerste foto.
<img src=" img113.imageshack.us/img113/6410/img0888p.jpg " width="800" height="600" />
29-03-2009 22:09 #1233560 door V700 register
Beantwoord door V700 register in topic Mooi werk tjerk
Mooi werk Boris! Prima te doen dus. Mocht ik m'n M46 eens in de prak hebben, dan weet ik dat het te doen is. En dan weet ik je ook te bereiken ;)
Alle foto's zijn genomen met daglicht. Dat is best een goed teken!
29-03-2009 22:13 #1233562 door V700 register
Beantwoord door V700 register in topic Hey hey Boris, goed om te
Hey hey Boris,
goed om te zien dat het gelukt is. Scheelde je toch een fikse wandeling of niet dan?
Jammer dat ik de tweede helft van de operatie niet meer kon zien.
Groeten en geniet!
Richard
29-03-2009 22:46 #1233570 door V700 register
Beantwoord door V700 register in topic mooie ombouw! Maar toch maar
mooie ombouw!
Maar toch maar geen afgedraaid motronic vliegwiel gemonteerd? (die ene die ik in de aanbieding had.)
grt,
Jan
30-03-2009 01:01 #1233585 door Boris Duijndam (GAST)
Beantwoord door Boris Duijndam (GAST) in topic Kan altijd nog ;-)
JanV schreef : mooie ombouw!
grt,
Jan
 Die kan er altijd nog onder hoor ;-) maar had niet het geld liggen voor overnemen en balanceren helaas alles op ze tijd he.
Groetjes Boris
16-02-2012 22:13 #1348338 door V700 register
Beantwoord door V700 register in topic hoofdremcylinder
Ik ben dezelfde swap als Boris van plan. Van bovenstaande verschillen was ik reeds op de hoogte (andere versnellingsbak steun en langere aandrijfas). Maar nu kreeg ik net te horen dat de hoofdremcylinder eventueel ook anders is? Voor 88 kan er ook een kabelkoppeling gebruikt zijn, en zou ik dus de hoofdremcylinder + leidingen ook moeten vervangen?Ik heb net als Boris een 760TIC van 86 met B230ET + M46 (OD).
Kort samengevat, wat moet ik allemaal van de 940 turbo meenemen om zonder problemen een swap uit te voeren? :)
16-02-2012 22:32 #1348342 door V700 register
Beantwoord door V700 register in topic Kijk als eerste of je al een
Kijk als eerste of je al een hydraulische koppeling hebt.
De hoofdremcilinder is niet anders, het enige is dat het reservoir er van een aansluiting heeft voor de koppeling-master-cilinder. Mocht je rembekrachtiger die aansluiting niet hebben kun je misschien ook de cylinder van een 260 nemen die heeft het reservoir ingebouwd.
Die 740/760/940 hydraulische cilinder kost nu trouwens 39 euro bij scandix.de. Leiding kun je goed van sloopauto nemen, 740 en 940 past. Pedaal voor een kabelbediende koppeling is ook anders. Ik verwacht trouwens dat jou auto gewoon een hydraulisch bediende koppeling heeft.
ALs je gaat swappen zou ik ook de bussen van de schakelstang en de schalen van de schakelpook meenemen. Even de kruisstukjes van de stang van pook naar bak voelen of die niet te veel speling hebben. Rubber bus van de houder van de pook (aan de bak) nog goed? Uiteraard de seals vervangen en nieuwe (Volvo) olie er in. De voering van het gewricht van de koppelingsvork kun je ook vervangen, die slijten ook. De Diesel M90 koppeling heb je ook nodig. Verder is er niet zo veel te doen, iig valt me niets meer in op dit moment.
16-02-2012 23:10 #1348348 door V700 register
Beantwoord door V700 register in topic verschil
Als je kabel koppeling hebt mis je 1 of 2 aansluitingen op je hoofdrem cillinder, ook moet je het verdeel blokje hebben, dit weet ik weer uit eigen ervaring omdat er bij mij binnenkort ook een M90 achter de diesel komt.
je kan beter het hele gebeuren voor jan met zn korte achternaam hebben dan dat je staat te kijken en op het laatste moment ergens nog iets vandaan moet vissen.
Tom.
  • Gerben Mol
16-02-2012 23:23 #1348352 door Gerben Mol
Beantwoord door Gerben Mol in topic Foto?
Ik heb enkele jaren geleden hier fototjes van gemaakt:
<img src="/sites/default/public_files/user7157/Photo00245.jpg" width="500" height="375" />
<img src="/sites/default/public_files/user7157/Photo00244.jpg" width="500" height="375" />
<img src="/sites/default/public_files/user7157/Photo00246.jpg" width="500" height="375" />
KoppelingsPedaal verschilt, moet je omzetten.
Er komt een leidinkje vanaf het reservoir van je rembekrachtiger, vaak zit het aansluitinkje wel op het plastic bakje maar is deze afgedopt, dopje eraf halen, rubberen leidinkje erop en gaan.(er komt 1 leidinkje vanaf, die gaat naar je master cylinder)
Vanaf de mastercylinder gaat er een metalen - flexi - pijp naar je slave cylinder bij de bak.
