good mechanic in or around rotterdam
20-11-2011 16:21 #1090076 door V700 register
good mechanic in or around rotterdam is gemaakt door V700 register
who can please tell me a good mechanic that i can trust????
dont mean oficiale dealer couse they're just to expensive..
thanks jongens :)
20-11-2011 16:27 #1337612 door V700 register
Beantwoord door V700 register in topic Maybe
Maybe you can contact Jelmar (Jelmar86) on this forum ? It could be helpful if you can mention the subjects you want the mechanic service for.
20-11-2011 18:02 #1337630 door V700 register
Beantwoord door V700 register in topic Yup
Yeah, i would say Jelmar as well.
21-11-2011 06:48 #1337709 door V700 register
Beantwoord door V700 register in topic well just of the top of my
well just of the top of my head..
engine is smoking..leakin oil somewhere under by the exhaust manifold..
than loosing power at start for a second or so while driving on LPG..
possible high gas consumpsion because of bad lamba sonde or catalitic converter..or both..
people told me i should also check injectors..
loosing a lot of cooling liquid..
centrale lockong dont work..
and some electics in on dashboard..
see there is enough..i should acctualy make a whole check up to know exactly what needs to be fixed..
so i quess i'll contact mister Jelmar for help..
thanks for advice..
