VROUWONVRIENDELIJK - niet klikken dus ;) (Engels, sorry...)
08-11-2011 19:06 #1089871
VROUWONVRIENDELIJK - niet klikken dus ;) (Engels, sorry...) is gemaakt door V700 register
MALE VS. FEMALE AT THE ATM MACHINE A new sign in the Bank Lobby reads:'Please note that this Bank is installing new Drive-through ATM machines enabling customers to withdraw cash without leaving their vehicles.Customers using this new facility are requested to use the procedures outlined below when accessing their accounts.After months of careful research, "MALE & FEMALE" procedures have been developed. Please follow the appropriate steps for your gender.' *******************************MALE PROCEDURE:1. Drive up to the cash machine.2. Put down your car window.3. Insert card into machine and enter PIN.4. Enter amount of cash required and withdraw.5. Retrieve card, cash and receipt.6. Put window up.7. Drive off.*******************************FEMALE PROCEDURE:(What is really funny is that most of this part is the truth!!!!)1. Drive up to cash machine.2. Reverse and back up the required amount to align car window with the machine.3. Set parking brake, put the window down.4. Find handbag, remove all contents on to passenger seat to locate card.5. Tell person on cell phone you will call them back and hang up.6. Attempt to insert card into machine.7. Open car door to allow easier access to machine due to its excessive distance from the car.8. Insert card.9. Re-insert card the right way.10. Dig through handbag to find diary with your PIN written on the inside back page.11. Enter PIN.12. Press cancel and re-enter correct PIN.13. Enter amount of cash required.14. Check makeup in rear view mirror.15. Retrieve cash and receipt.16.. Empty handbag again to locate wallet and place cash inside.17. Write debit amount in check register and place receipt in back of check book.18. Re-check makeup.19. Drive forward 2 feet.20. Reverse back to cash machine.21. Retrieve card.22. Re-empty hand bag, locate card holder, and place card into the slot provided!23. Give dirty look to irate male driver waiting behind you.24. Restart stalled engine and pull off.25. Re-dial person on cell phone.26. Drive for 2 to 3 miles.27. Release Parking Brake.SEND THIS TO A MAN WHO NEEDS A LAUGH, AND TO THE LADIES who can handle it.... A lady sent it to me. She was laughing, too.
08-11-2011 19:11 #1336243
Beantwoord door V700 register in topic oude grap
sjeu deze grap heeft wel een heel erge baard...Dit is ongeveer uit 2002..
08-11-2011 19:26 #1336252
door Mathy van Nisselroy
Beantwoord door Mathy van Nisselroy in topic Klassieker
Hallo Jeroen
Maar hij blijft leuk.
08-11-2011 19:27 #1336254
Beantwoord door V700 register in topic Wel
heel goed dat jij zelfs het jaartal onthoudt waarin de grap gemaakt is maar ik had hem nog niet gehoord/gelezen, Jeroen.
08-11-2011 20:55 #1336284
Beantwoord door V700 register in topic Kwam me wel vaag bekend voor
maar toch niet bekend genoeg.. Of misschien moest ik wel aan iemand anders denken
08-11-2011 22:25 #1336305
Het was een wat allergische reactie inderdaad. Maar ik heb m ongeveer 25 keer voobij zien komen in mijn mailbox de afgelopen jaren (ja dat kan ook 24 of 26 keer zijn )
Beantwoord door V700 register in topic plusminus
ongeveer het had ook zomaar 1998 kunnen zijn, of 2003.Tomaat schreef : heel goed dat jij zelfs het jaartal onthoudt waarin de grap gemaakt is maar ik had hem nog niet gehoord/gelezen, Jeroen.
- Chris Boessenkool
08-11-2011 23:14 #1336322
door Chris Boessenkool
Beantwoord door Chris Boessenkool in topic Moppentrommel
Als we dan toch met flauwe moppen bezig zijn
Deze kwam ik vandaag ook nog tegen:
Haynes: Rotate anticlockwise. Translation: Clamp with molegrips then beat repeatedly with hammer anticlockwise. You do know which way is anticlockwise, don't you? Haynes: Should remove easily. Translation: Will be corroded into place ... clamp with adjustable spanner then beat repeatedly with a hammer. Haynes: This is a snug fit. Translation: You will skin your knuckles! ... Clamp with adjustable spanner then beat repeatedly with hammer. Haynes: This is a tight fit. Translation: Not a hope in hell matey! ... Clamp with adjustable spanner then beat repeatedly with hammer. Haynes: As described in Chapter 7... Translation: That'll teach you not to read through before you start, now you are looking at scary photos of the inside of a gearbox. Haynes: Pry... Translation: Hammer a screwdriver into... Haynes: Undo... Translation: Go buy a tin of WD40 (industrial size). Haynes: Ease ... Translation: Apply superhuman strength to ... Haynes: Retain tiny spring... Translation: "Crikey what was that, it nearly had my eye out"! Haynes: Press and rotate to remove bulb... Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part and remaining glass shards. Haynes: Lightly... Translation: Start off lightly and build up till the veins on your forehead are throbbing then re-check the manual because what you are doing now cannot be considered "lightly". Haynes: Weekly checks... Translation: If it isn't broken don't fix it! Haynes: Routine maintenance... Translation: If it isn't broken... it's about to be! Haynes: One spanner rating (simple). Translation: Your Mum could do this... so how did you manage to botch it up? Haynes: Two spanner rating. Translation: Now you may think that you can do this because two is a low, tiny, ikkle number... but you also thought that the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you). Haynes: Three spanner rating (intermediate). Translation: Make sure you won't need your car for a couple of days and that your AA cover includes Home Start. Haynes: Four spanner rating. Translation: You are seriously considering this aren't you, you pleb! Haynes: Five spanner rating (expert). Translation: OK - but don't expect us to ride it afterwards!!! Translation #2: Don't ever carry your loved ones in it again and don't mention it to your insurance company. Haynes: If not, you can fabricate your own special tool like this... Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!! Haynes: Compress... Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search for it in the dark corner of the garage whilst muttering "******" repeatedly under your breath. Haynes: Inspect... Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"! Haynes: Carefully... Translation: You are about to cut yourself! Haynes: Retaining nut... Translation: Yes, that's it, that big spherical blob of rust. Haynes: Get an assistant... Translation: Prepare to humiliate yourself in front of someone you know. Haynes: Refitting is the reverse sequence to removal. Translation: But you swear in different places. Haynes: Prise away plastic locating pegs... Translation: Snap off... Haynes: Using a suitable drift or pin-punch... Translation: The biggest nail in your tool box isn't a suitable drift! Haynes: Everyday toolkit Translation: Ensure you have an RAC Card & Mobile Phone Haynes: Apply moderate heat... Translation: Placing your mouth near it and huffing isn't moderate heat. Translation #2: Heat up until glowing red, if it still doesn't come undone use a hacksaw. Haynes: Apply moderate heat... Translation: Unless you have a blast furnace, don't bother. Clamp with adjustable spanner then beat repeatedly with hammer. Haynes: Index Translation: List of all the things in the book bar the thing you want to do! Haynes: Remove oil filter using an oil filter chain spanner or length of bicycle chain. Translation: Stick a screwdriver through it and beat handle repeatedly with a hammer. Haynes: Replace old gasket with a new one. Translation: I know I've got a tube of Krazy Glue around here somewhere. Haynes: Grease well before refitting. Translation: Spend an hour searching for your tub of grease before chancing upon a bottle of washing-up liquid. Wipe some congealed washing up liquid from the dispenser nozzle and use that since it's got a similar texture and will probably get you to Halfords to buy some Castrol grease. Haynes: See illustration for details Translation: None of the illustrations notes will match the pictured exploded, numbered parts. The unit illustrated is from a previous or variant model.
09-11-2011 08:43 #1336345
Beantwoord door V700 register in topic Maw
Haynes in het kort, hahaha.
