Hendel automaat
25-01-2021 18:56 #1110437
Hendel automaat is gemaakt door V700 register
Het rubber van mijn automaathendel is volledig vergaan. Nu heb ik een 'nieuwe' gevonden. De drukknop is eraf, maar die is wel meegeleverd. Verder heb ik een veertje en stift. Rara hoe zit dat in elkaar? Ofwel, hoe zorg ik ervoor dat de knop weer verend op de hendel gemonteerd zit? Ik heb het puzzeltje nog niet op kunnen lossen.
- Jerry Stam (GAST)
26-01-2021 09:59 #1465273
door Jerry Stam (GAST)
Beantwoord door Jerry Stam (GAST) in topic Van turbobricks
if you have the rounded one just unhook/disconnect the O.D. button, grab the knob with both hands and quickly pull up. You dont have to take the whole thing apart.
Careful dont hit your self in the face.
Een uitgebreidere versie van: www.brickboard.com/FAQ/700-900/Transmiss...#RemovingShifterKnob
940 Cars. [Tips from Jay Simkin] Tools needed: soldering iron (25-40 watt), needle-nose pliers [bent tip], pocket knife or utility knife.
- Remove overdrive switch from knob housing. Using tip of utility/pocket knife, pry the over-drive switch from the knob. Little effort is required to do this.
- Get slack in wires to overdrive switch. Using bent-tip needle nose pliers, grip the insulation sheathing around the wires that go to the switch. Pull GENTLY. There is perhaps 1/4" of slack to be had - and you will need it - but you must pull gently on these wires. They are thin. (If you break them, the shifter will have to be removed and disassembled to replace this harness. This is a non-trivial task.)
- De-soldering wires to overdrive switch. Once you have the switch body outside of the shifter knob housing, use white-out to mark one side of the switch box and the wire that runs to that side of the switch. Use the soldering iron to separate the wires from the switch body. If the wires have been spot welded, cut the wire as close to the switch tab as possible but do not cut off the tabs themselves. Set the switch aside.
- Removing the shifter knob. The gear shift knob is held to a hollow steel shaft - square in cross section - by small tabs on the inside of the polymer knob. These tabs are not destroyed when the knob is removed. Rather, they are pulled out of recesses in the metal shaft. The tabs reseat when the knob is reinstalled. Move the shift lever to the 2nd gear position. Grip the shifter knob with both hands and pull upwards using a robust tug. It will release suddenly. Protruding from the gear selector housing, you will see a square steel shaft, with a plastic shift unlock rod inside of it. Nothing need be done with these: There is no link between the plastic rod and the button. The top of the plastic rod bears on the underside of the button, mounted in the top of the shifter knob.
- Attaching guide wire. To ensure proper routing of overdrive switch wires inside the shifter knob housing, solder the end of a piece of thin, flexible wire to the end of one of the overdrive wires. Thread the guide wire up through the channel in the shifter knob housing, and out through the opening for the overdrive switch.
- Installing the shifter knob. Making sure that the opening in the shifter knob faces towards the back of the car (and the shifter button faces the console), put the shifter knob onto the square shaft. It will slide freely, until it comes to about 1/4" from the bottom. As the shifter knob slides downwards, pull gently on the guide wire, to pull the overdrive wiring harness up towards the overdrive switch housing opening. Once you can see the end of the wires through the opening in the knob, use the bent-tip needle nose pliers to pull the wires out through the opening.
- Seating the shifter knob. Using the flat of your hand, press down firmly on the shifter knob. This will seat it. It will self-lock into place: you will feel the clunk as it self-locks. The plastic rod inside the square metal shaft will self-position against the underside of the shifter knob button. Check that this is so by moving the gear selector through its positions. It should do so.
- Re-installing the overdrive switch. Using your soldering iron, attach the overdrive switch wires to the switch tabs. Put the key in the ignition and move the key to position two. Press the over-drive switch button several times. If the arrow-head indicator on the right side of the warning light row at the bottom of the cluster goes from on to off as you move the switch button, you have a good contact. If not, re-solder and repeat the test.
- Closing-up. Push the overdrive wires into the recess, gently. Press the overdrive switch back into its recess.
- Re-test. With the ignition key in Position II, function test the over-drive switch again. If it does not cause the arrow-head indicator to go on and off each time, remove switch from shifter knob housing and check the solder joints.
Not knowing that the shifter knob is not linked to the shifter's internal mechanism, I dismantled the shifter, which I bought at a salvage yard. If you want to remove the knob at a salvage yard, you need only cut the over-drive switch wires, and pull the knob free. Only the overdrive switch wires keep the shifter knob from being removed without tools. [Doug Peterson] Doug could not remove the shifter knob/rod at all, ended up breaking the knob assembly off. He also broke off the plastic shift lever rods within, repairing them using superglue and metal pins drilled into each broken end.
- Reinier Verbeek
- Elite lid
07-02-2024 12:29 #1474461
door Reinier Verbeek
Beantwoord door Reinier Verbeek in topic lossolderen dus, die knop van de overdrive!
eerste het knopje eruit halen en lossolderen en dan als een getikte aan de knop rukken tot hij losschiet. Pas op dat je jezelf niet voor je gezicht slaat.
Ik heb het verder nergens op het forum gelezen en net op de verkeerde manier ontdekt, dat je eerst het knopje van de overdrive eruit haalt: heel voorzichtig met een mesje, je hebt minder dan een cm speling. En dan moet je de draden los solderen, terugstoppen en dan moet de hele hendel eraf gerukt.
En dan kan je redelijk bij het lensje van de verlichting en de stripjes die PRND12 afdekken, die vaak afbreken en heel moeilijk zijn te lijmen. Weet iemand of dat dingetje nog leverbaar is?
Met vriendelijke groet,
Reinier
Reinier
- Jerry Stam (GAST)
07-02-2024 12:52 #1474462
Beantwoord door Jerry Stam (GAST) in topic Draden trekken
- Reinier Verbeek
- Elite lid
13-02-2024 22:42 #1474498
Beantwoord door Reinier Verbeek in topic Hij zit erin
Maar losmaken zonder eerst de overdrive UIT/AAN knop los te solderen gaat mij nooit lukken. En ik kreeg ook helemaal geen speling op de draad door vanonder af te trekken. Bij mij zit ie ergens onder de pook-scharnier vast-vast.
Dus eerst knoppie eruit met een zakmesje of een of twee electriciteitsschroevedraaiertjes, knoppie van de overdrive lossolderen en dan trekken aan de pook (met een ruk) als hij 2 of 1 staat en pas op dat je jezelf niet raakt met de losgeschoten pook.
Groet reinier
Groet reinier
