Volvo AC Ventielen
- Jerry Stam (GAST)
02-07-2020 10:57 #1109912
door Jerry Stam (GAST)
Volvo AC Ventielen is gemaakt door Jerry Stam (GAST)
Vond deze op internet. Goed even te bewaren hier:
Common fault on all 700/900 series with aircon is the failure of the 2 way vacuum bellow which controls one of the air circulation shutters, part number 9463042 for LHD, 9463044 for RHD. This cause a vacuum leak on the climate system, and the most common symptom of failure is that air stops coming out of dash vents under acceleration but resumes when you release the accelerator pedal. In severe cases the air circulation shutters may stop functioning altogether, with the system permanently stuck on floor/demist position. Volvo no longer produce/stock this vacuum bellow. I’ve known for a while that AC Delco vacuum below 15-71438 can be used as a substitute, however they are still sufficiently different to the point that it’s not going to be a direct fit. The orientation of the metal actuator rod & position of the hole on the rod is different, also the 2 vacuum ports will be in a different position so I wonder if the vacuum hoses are long enough to reach it. Then I noticed that the failure (vacuum leak) is always caused by a tear on the rubber seal around the actuator rod, so what if I just swap the rubber seal over... and it worked!!! I have just repaired my genuine Volvo 9463044 vacuum bellow using the rubber seal from AC Delco 15-71438 vacuum below.
02-07-2020 13:35 #1461622
Beantwoord door V700 register in topic Top
Goede info!
- Piet van der Plas
02-07-2020 16:33 #1461627
door Piet van der Plas
Beantwoord door Piet van der Plas in topic Mooi gevonden! Maar volgens
Mooi gevonden! Maar volgens mij is die Delco vacuumklep ook al niet meer leverbaar, behalve dan soms op Ebay.
Het meest interessant vind ik eigenlijk dat het vacuum lek veroorzaakt wordt door een ingescheurd rubber. Omdat een vacuum lek meestal wordt veroorzaakt door de dubbelklep zou je bij het slopen van een 940/960/850 uit de twee andere kleppen vaak nog goede rubbers moeten kunnen halen.
Nooit aan gedacht om hier naar te kijken.
Piet
Piet
- Yannic Nuijt
03-07-2020 21:58 #1461665
door Yannic Nuijt
Beantwoord door Yannic Nuijt in topic Delco
Helaas zijn die Delco kleppen eigenlijk ook niet meer te krijgen of voor zulk hoge prijzen dat het eigenlijk ook niet interessant is.
Wat misschien wel interessant is om te weten wat de inbouw diameter is van het gat in de behuizing van de balg en de diameter van het asje. Want zoals ik het zie is het niet veel meer als een verlengde doorvoertule welke je bijvoorbeeld bij Rick Donkers zo kan kopen voor nog geen euro, maar dan moeten ze alleen wel de juiste maat hebben.
- Jurriaan Nijkerk
04-07-2020 15:06 #1461674
door Jurriaan Nijkerk
Beantwoord door Jurriaan Nijkerk in topic Creatief
Bij dit soort zaken moet je nu eenmaal een beetje creatief zijn.Vaak kun je onderdelen vervangen door iets geheel anders. Zoals een vriend van me, fysiotherapeut het weet te verwoorden, het gaat er niet om dat het origineel werkt, maar dát het werkt.
Maar in ieder geval een goed stuk!
- Jerry Stam (GAST)
08-09-2020 20:34 #1462844
Beantwoord door Jerry Stam (GAST) in topic Paar foto's
- Yannic Nuijt
09-09-2020 06:30 #1462850
door Yannic Nuijt
Beantwoord door Yannic Nuijt in topic Afmetingen?
Wat is afmeting van de as qua diameter, het gat in het plastic huis en hoe lang moeten ze ongeveer zijn? Heb mogelijk wel iets gevonden maar wist niet welke afmetingen er nodig zijn.
