Overzicht differentieel types
- Piet van der Plas
07-01-2010 21:55 #1078450
door Piet van der Plas
Overzicht differentieel types is gemaakt door Piet van der Plas
Volvo achterwielaandrijvers konden zijn voorzien van een klauwsper (locking differential) van Eaton (spert 0% of 100%) of van een slip differentieel (limited slip differential) van Dana (spert tussen 25% en 75%).
Het type is te herkennen dmv een sticker.
Info hierover kwam ik onlangs tegen; zie: www.justanswer.com/questions/10ti5-do-al...gon-have-limetedslip De layout van deze website is wel wat onduidelijk; de tekst met aangepaste layout ziet er als volgt uit: The Drive Axle Type and Gear Ratio Information Plate (sticker) is located on the Left Axle Tube for Solid Axle Type drive units, and on the Differential Center Section for Independent Rear Suspension (IRS ) Type drive units. Type 1030 Solid Axle Type. Used from 1983 to 1989 in various 700 series. Type 1031 (early) Solid Axle Type. Heavy duty version of Type 1030. Used from 1983 to 1990 in various 700 and 900 series. Has stamped steel rear cover. Type 1031 (late) Solid Axle Type. Updated version of Type 1031 (lighter housing). Used from 1990 to 1995 in various 700 and 900 series. Has cast aluminum rear cover. Type 1035 Independent Rear Suspension (IRS ) Type. Used from 1988 to 1990 in 4 door 760 series (NO wagons). Used from 1988 to 1991 in all 780 series. Used in 1991 in 4 door 940SE series (NO wagons). Used from 1992 to 1994 in 4 door 960 series (NO wagons). Type 1041 (early) Solid axle Type. Limited Slip (Dana) version of Type 1031 (early). Used from 1983 to 1990 in various 700 and 900 series. Has stamped steel rear cover. Type 1041 (late) Solid axle Type. Locking Differential (Eaton) version of Type 1031 (late). Used from 1990 to 1995 in various 700 and 900 series. Has cast aluminum rear cover. Type 1045 Independent Rear Suspension (IRS ) type. Locking Differential (Eaton) version of Type 1035. Used from 1988 to 1990 in 4 door 760 series (NO wagons). Used from 1988 to 1991 in all 780 series. Used in 1991 in 4 door 940SE series (NO wagons). Used from 1992 to 1994 in 4 door 960 series (NO wagons). Type 1055 Independent Rear Suspension (IRS ) type. Used from 1995 to 1997 in 960 series. Used from 1998 in S90 / V90. Type 1065 Independent Rear Suspension (IRS ) type. Locking Differential (Eaton) version of Type 1055. Used from 1995 to 1997 in 960 series. Used from 1998 in S90 and V90. Used from 1997 in 850 series equipped with All Wheel Drive (AWD). Used from 1998 in S70 / V70 equipped with All Wheel Drive (AWD).
Piet
Piet
08-01-2010 08:40 #1260260
Beantwoord door V700 register in topic Helder
Mooi overzichtje. Misschien kan een moderator er een info-pagina van maken?
Alleen lopen alle 900 series maar door tot 1995, of komt dat omdat ze in de States in 1995 gestopt zijn met de 900 ofzo?
In dat geval heeft een MY 1998 940 dus een 1031 of 1041?
08-01-2010 08:47 #1260261
Beantwoord door V700 register in topic Informatie
Kan iedereen hoor, in ieder geval de verenigingsleden. Mbv menu aan linkerzijde "maak een.... informatiepagina". Voel je dus vrij om er eentje te maken als je aanleiding voor een mooie informatiepagina ziet. Het is natuurlijk het leukst als iedereen een bijdrage levert, op die manier kunnen we meer infomatie bij elkaar brengen dan als het alleen van de moderators afhangtPNordic schreef : Misschien kan een moderator er een info-pagina van maken?
08-01-2010 09:33 #1260264
De <a href="/node/29969" target="_blank">pagina</a> is er nu maar ik zie hem niet terug in het overzicht bij Transmissie en aandrijflijn, terwijl ik hem daar wel heb ondergezet.
Doe ik iets verkeerd of?
Beantwoord door V700 register in topic Aha
Aha, natuurlijk.henk 940LPT schreef : Kan iedereen hoor, in ieder geval de verenigingsleden.
08-01-2010 10:11 #1260269
Beantwoord door V700 register in topic Toch wel.
Shift - refresh?CTRL+F5 bijvoorbeeld, want ik zie hemer wel tussen, als achtste, meen ik.PNordic schreef : Doe ik iets verkeerd of?
08-01-2010 10:33 #1260275
Beantwoord door V700 register in topic Dat
Dat kan kloppen. Onze informatiepagina's zijn ingedeeld in categorieen, die moet je bij aanmaken ook selecteren. Je kunt alle informatiepagina's die er zijn bekijken via "documentatiepagina's" in het menu aan de linkerzijde. Daar zie je die categorieen ook weer terugkomen.Het overzicht via de vraagbaak maakt helaas geen gebruik van die categorieen maar van een andere structuur, de zogenaamde bookpage structuur. Als je daar een pagina in wilt hebben dan moet je die daar "hard" inhangen (onderdeel maken van een bepaald hoofdstuk). Je moet die pagina dan invoegen in die bookpage structuur en die die onder het juiste hoofstuk plaatsen. In dit geval "transmissie en aandrijflijn". Alle pagina's in de vraagbaak zijn informatiepagina's maar niet alle informatiepagina's staan in die bookpage structuur. Het pagina onderbrengen in de bookpage structuur kunnen alleen moderators, ik zal dit vandaag voor jou doen voor deze pagina. Mijn opmerking was niet helemaal juist, een informatiepagina maken kan iedereen, onderbrengen in de vraagbaak dus niet. Mijn excuses hiervoor.Overigens hebben we ooit nagedacht om de vraagbaak op te bouwen aan de hand van de categorieen en de bookpage structuur los te laten. Als je dan een infopagina maakt geef je nog steeds de categorie aan. Open je dan de vraagbaak op dan worden alle pagina's uit die betreffende categorie opgezocht en in een overzicht weergegeven. Nieuwe pagina's zouden daar meteen tussen staan zonder tussenkomst van moderatoren. Helas is het daar nog niet van gekomen, ook vanwege een relatief groot aantal pagina's (paar honderd) die je dan allemaal handmatig bij langs moet.
08-01-2010 12:09 #1260295
Beantwoord door V700 register in topic Staat erin
Hij staat erin hoor
