Dit is wat het demoprogramma aangeeft:
On ââ?¬Ë?96/ââ?¬â?¢97 850 cars with the 16 way ââ?¬Ë?OBDIIââ?¬â?¢ socket, and some other models, some of the control modules use ââ?¬Ë?flashââ?¬â?¢ codes, this program is not designed to work with these modules.The controls for these have been coloured yellow in the program.
THE USE OF THE FOLLOWING INFORMATION IS ENTIRELY AT THE USERS RISK
To retrieve the flash codes the following procedure can be adopted:Connect an LED, with the correct polarity, in series with a 1k8 ohm resistor, between pin 16 (+) and pin X, where X is the pin corresponding with the module to be read. Connect a push to make switch between pin X and pins 4 or 5 (-).The circuit can then be used in the same way as the pre �96 diagnostic sockets, situated in the engine compartment.ForMotronic 4.3 or Fenix 5.2, X = 3.ECC , X = 6, Timer Type 4, X = 9.Cruise Control, X = 13; 900 & S/V 90 ABS, X = 12 .
Misschien hebbie-dur-wat-an.
Rob
